Originally posted by SteveS
I have a 1994 Explorer XLT. During cooler weather months a "chirping" noise appears when I press on the accelerator pedal. The noise becomes more rapid the harder I accelerate and the noise slows down and then disappears when I take my foot off the accelerator. The noise does not seem to have anything to do with the speed of the vehicle: if I acceleate to 60 mph and take my foot off the pedal, the chirping stops. The noise only develops after the vehicle sits overnight and the noise usually continues until I have driven for about 30 minutes before turning the engine off. For the rest of the day the noise does not appear. I have replaced the blower fan in the dash, the serpintine belt, the belt tensioner pulley, and the engine fan and fan clutch, but I still have the noise! A friend suggested it may be the camshaft position sensor. I have run out of possible solutions. Do any of you guys know what this noise could be? Any help would be greatly appreciated.
Hi Steve-
We have a 94 as well. We use to have the exact same symptoms as you have described in your post. In fact, your post brought a smile to my face because I too tried replacing most of the stuff you already have in an attempt to get rid of the 'chirp'. What a frustrating journey!! Our noise did indeed end up being the camshaft position sensor. We were finally able to isolate the problem with an automotive stethiscope (sorry about the spelling). This sensor is located at the far end (rear) of the motor as you stand directly in front of the grill. You can also verify the noise by starting the vehicle on a colder morning, when the noise is prevalent, run around to the passenger side wheel-wheel and reach your left hand down and grab around the sensor. When I wrapped my hand around the sensor the noise would go away. (It is kinda hard to find initially). You may want to use a mirror and flashlight to initially find it. There is also a wiring harness connection back there that connects the the top of the sensor.
I could only find the sensor to be sold at Ford, and it's painful.........about $400 !! I did some searching and was blessed to find one at an engine salvage/used auto place and saved significant money.
I received the removal/replacement procedure from Ford and my buddy who is ASE certified, was able to do the work for me, but it wasn't that fun to do.
But, the good thing is, the noise is now gone.
Hope this helps,
Brandon.
