chris c
- December 13, 2002
- New York
- 91 XLT
started all the stuff i needed to get done to my truck tonight.
first off i was suffering from the 1>2 cold shift problem. i dropped the tranfer case and removed the shift governor. i did not remove the tail shaft extension on the transmission to remove the shift govenor. is there and reason to besides easy access to the bolts holding the shift governor? it was working but def. sticking. i polished it with 2000 grit sand paper and cleaned it up. the galleys were all clogged up from small metallic residue from the metal wearing. i guess that should be expected with 202k miles on it!
i also put in a new vacuum modulator just for kicks. heh, i under the car right. i read some posts about removing the cat or an access panel under the passenger seat. i removed the head shield and swapped the vacuum modulator without touching the cat or using the access panel under the seat. you have to see with your hands but it can be done...
tomorrow im on to the front axle universals!
