Cleaning A4LD valve body | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
jakerot
Clifton, NJ
92 4DR
Hello all!!
Does anyone know of a simple procedure for cleaning the valve body on an A4LD after it is removed??
A4LD tech manual only says to use a "solvent". I was thinking on using carb cleaner. Is that OK??
Thanks for your replies
Best Regards,
jakerot
Yep carb cleaner works, just make sure you get it all off before you put it back in...carb cleaner + tranny fluid = dead tranny...
Non chlorinated brake cleaner is better. If you shop right you can buy it for a buck a can. LItle or no residue, unlike carb cleaner. I buy it a case at a time on sale at Kragen for a buck a can.
Happy Exploring
Chris
ps. A case just about does a whole trannie, inside and out.
Thanks for your replies fellas!!!
