rmccullough
- March 25, 2005
- Belgrade, MT
- '96 Ltd
I have a '96 Ford Explorer Limited, 4DR, 5.0 V8, not 4x4.
Starting yesterday, it seems when the climate controls are activated I get a repetitive buzzing & clicking noise from inside the dash. It sounds like it is coming from the passenger side.
I searched around the forums a little bit but did not see any other posts describing this problem. I could be searching with the wrong keywords (click + dash).
Since the problem only occurs when I turn on the climate controls (Max/AC or Heat Automatic), I am wondering if it is part of the "blend door" problem that sounds pretty common.
http://www.explorerforum.com/forums/showthread.php?t=183742
Since I live in Montana, not using the heat is not really an option.
Any ideas or suggestions? Is the repetitive buzzing & clicking noise an indicator of the blend door problem or something else?
