I have a clicking noise coming fro the rear when turning and gets really loud when going up an iincline? any thoughts?
"Clicking" sounds during turns is a classic symptom of bad cv joints. Your independent rear suspension Explorer has CV axles in the rear, as well as the front, so check those.
The 3rd gen Explorers are also notorious for bad rear wheel bearings. Jack the rear wheels off the ground, and give them a good shake. If there is any wobble, you need wheel bearings.
Well, going uphill, I would assume you are trying to maintain speed, thereby putting the cv joints under load. So, it could be. Again, same with the wheel bearings.
