Clicking noise on acceleration, not lifter | Ford Explorer - Ford Ranger Forums - Serious Explorations
Mangus17
1995 explorer xlt
Everytime I accelerate theres a clicking noise that sounds like it's coming from the drivers side of the engine bay while driving, when put in neutral it doesn't make any noise 96 5.0 rwd
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Exhaust manifold leak I'd assume. Is it louder when cold?
Littleant
Location
Vermont
Orleans
2010 Mountaineer 4.0
I know you said it's rwd but If 4wd check the driver side cv shaft boot and see if the boot is not torn. The CV joint will make a clicking noise when going bad hot or cold. More pronounced when turning. Try turning the steering left or right and move forward slow and see if the clicking is there. If not 4wd I would check what boominXplorer said. Manifold could be cracked large enough that it won't close up when hot.
Mangus17
1995 explorer xlt
Its def not 4 wheel drive, I'm going to be adding it tho because it is a Georgia vehicle and in amazing condition
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
allright the 5.0 trucks are RWD or AWD
To turn a RWD truck into a 4x4 you will have to replace the transmission
Look at the exhaust manifold on the drivers side. Missing any bolts? The front ones?
Look for exhaust leak around the exhaust manifold, black soot will be present.
Often the exhaust manifolds will come apart or lose a gasket
The 96 exhaust manifolds are welded together like patch work from the factory, and they have been known to develop leaks
Let us know what you find
