Clicking rattle ? | Ford Explorer - Ford Ranger Forums - Serious Explorations
Clicking rattle ?
Ashley31
England
1997 4.0 SOHC Explorer
hi all very recently I’ve noticed what I can only describe as a click/rattle coming from bottom of the engine sounds like it’s coming from propshaft tbh, sounds like if you there a piece of metal in a tin and shuck it goes away when it’s in park or neutral only when I’m drive any idea ? She does have a slight leak at bottom of box-propshaft too
J_C
Florence, KY
1998 XLT 4WD 4.0L SOHC
Maybe just a loose heat shield on the exhaust is rattling? I had to secure mine by tying it down with wire around a decade ago on my '98. Plain old 14ga solid core copper wire has lasted at least as long as the factory heat shield welds did.
Then again my concern about catching brush on fire from the exhaust, or expectation that those small thin things would protect the exhaust from rocks is low. In other words if I'd torn them off instead of strapping them down, I wouldn't have missed them but strapping them down was so easy to do and free with a scrap of wire I already had.
Ashley31
England
Worth trying that thanks will have a look over the weekend
J_C
Florence, KY
^ maybe, but
Seems like most people had reported the timing chain rattle on cold startup, idling.
