Clicking Sounds after changing spark plugs | Ford Explorer - Ford Ranger Forums - Serious Explorations
yorgeyr
newport news ,va
01 ford explorer sport
Just changed all my spark plugs , engine started making a click sound , checked all the spark plugs again and the wiring . Also checked where the plugs go in all the wires are in the right position
waskly
Crooklyn NY!
nothing fell in the plug hole right?
Doomie17
harford county, md
04 limited, 93 xlt
did you check the gap and make sure there right
yorgeyr
newport news ,va
I gapped them before putting them in .... Any other ideas
budwich
Ottawa, Ont
96 XL
one of your wires is "bad" or not connected solidly to a plug... my guess
yorgeyr
newport news ,va
SoNic67
Newport News, VA
2001 V8 (Eddie Bauer) AWD
Gap them? What kind of plugs did you install? Most of the platinum ones come pregapped to the right size.
yorgeyr
newport news ,va
I just made sure they were still gaped from all the packaging and shipping
waskly
Crooklyn NY!
the plugs might be pre gapped at the factor. not after shipping and receiving and handling.
Facimeor
1998 XLT
Path of least resistance:
You probably have a bad plug wire that is crossing something grounded and sparking across that gap. It can happen if a boot is old and worn or if a wire has been rubbing on something for a long time, then you move the wire doing plugs and break that outer jacket or change its relationship to the ground. You should be able to hone in on which one os making the noise though.
yorgeyr
newport news ,va
i also placed new wires so the wires wouldnt be bad or old.... Gonna take spark plugs out again and place them back in....
jremington59
Watertown, NY
1997, 99 and 2000 5.0's
Does the clicking sound like electricity? After dark go out and start it and take a spray bottle and mist all the wires. If you have anything arcing you'll see it.
xplorer_f150
so il
97 awd 5.0 and 95 F1504X4
Spark knock. Or could be what i just had happen to me drivers side 3rd plug, boot popped off a bit could hear it but couldn't find it till I was in litterly the dark.
yorgeyr
newport news ,va
Okkkkkkkk so i just misted my spark plugs/ wires (when it was dark) no sparks but didnt notice some smoke or steam come off the 4th spark plug area in other words , drive side , back of engine . Checking all the wires / spark plugs in the morning for 10th million time
yorgeyr
newport news ,va
engine was also not started all day so i dont think the engine could be that hot that quick in creat steam
yorgeyr
newport news ,va
This morning is not going to well , under neath my 1 2 3 spark plugs (left side) my car is smoking , not the from the spark plugs thou ..... Check all the spark plugs there fine, all the wiring is right but now i got smoke coming out my engine and the same clicking sound..... any ideas would helpppp thank you guys
yorgeyr
newport news ,va
ook sooo the smoke was just from extra coolant sooooooo nvmmm about that oneee but clicking sound still is thereeee
Joe Dirt
07 Camry
Do you still have the old wires? You can try swapping them back on...
Is it just the fuel injectors clicking? Cracked/loose exhaust manifold?
davemengel
Rochester, PA
'98 Sport
Psh if the plugs and wires are good then could be the infamous cam click.
What's the infamous cam click? I think I may have the same prob after tensioner change...I caught this post after having the same problem click after changing driverside tensioner and plugs
