donalds
- July 12, 2015
- Location
- Stem
- Nc
- 1999 ford explorer sohc
Because that's at least a 1/2 day (probably more like a full day) of my life I'd never get back. Besides, if you go that route you're almost guarantied to have a new problem that you created by pinching/pulling wires or vacuum hoses reinstalling the dash. I'm usually a proponent of doing things the "right way", but if I have a broken blend door I'm cutting the heater box with my Dremel. If you have a leaking heater core, that's a different story.
I'm not saying I wouldn't cut the box but I'm ocd so I would probably do both heater core and blend door at the same time if either when badWith the age of these trucks and the brittleness of the plastics and wires, I wouldn't do the dash removal. I think it quotes as a 16 hour job to fix the blend door that way? I may be wrong though. You have to figure, in that video he started with a stripped dash. The blend door "surgery" with the hacking of the heater bx can take 45 minutes to 3 hours.
Never thought of the plastic being brittle
I haven't had that experience on my truck
But I understand that said I'd pull the dash over a weekend but I am meticulous so I probably wouldn't break things pulling it but I understand that to
I figured I'd put the info out there
If I did cut the box it would have to be done in a very clean way or it would bug the he'll out of me
