skoal_mint
- September 19, 2005
- Geraldton ontario
- 97 explorer sport 4.0
well today i decided to throw 2 12'' kickers and 10" kenwood subwoofer in the back of my explorer....i build a huge long box and mounted the subs in...
but im getting bad clipping..i'll give you some info on my setup
Kenwood DB+ - 1000W 250WRMS
2 KICKERS - ???W
KENWOOD AMP 1000w max...200W@4ohm, 400W@2ohm 500W@1ohm
i have all three sub wired in siries on 4 ohm....are my subs clipping becasue the amp is set at 4ohm's- 200WRMS
should i switch it to 2 ohms then i will have a higher RMS wattage on the amp for all three subs, then i will have to wire the subs in parallel and rise of blowing the kicker subs becasue their are probly 200W each
2 KICKERS - ???W
