clunking in rear end after superlift | Ford Explorer Forums - Serious Explorations
colindo94
Cameron Park, CA
94' XLT
I got the superlift on and was drivig and noticd a cluncking noise in the rear end. I found something on this problem and it said the new bracket for the soa in the rear allows the axle to slide back and forth causing the clunk noise. I just wanted o know...if i weld the new bracket to the axle will it fix the problem. If anyone knows anything about this problem the feedback would be great. Thank you.
It'll fix the problem if that's where the noise is coming from.
When does it clunk? Are the U-bolts tight?
