hatched91
- October 2, 2005
- godfrey, Illinois
- 1997 sport ohv 5spd
okay, so i have read a bunch of stuff on the forums about bleeding clutches. i bought a new master clyinder, new slave cylinder, new clutch, and new flywheel. so everything except the tube going from the master clyinder to the slave cylinder is new, and there seems to be no leaks. i have tried and tried again to bleed my clutch and when the cap is off, i get a steady stream coming out from the slave cylinder bleeder valve and still no pressure on the clutch pedal. i did the bleeding procedure that someone had posted a link on in the explorer forums, but still no pressure. tried bench bleeding the master cylinder and the slave cylinder was supposed to come pre-bled and pre-filled. i'm stumped. anyone have any idea as to what to try?
