i really dont think anything is binding, the trans stabbed smoothly and well this time i put it in. my friend that is a mechanic said he just did a clutch on a mazda pickup and he said he's never going to do it again because it's such a huge PITA. he printed me up the exact procedure. summed up it goes like this:
1)open check valve on the plastic rubber hose, depress clutch pedal, close valve, repeat.
2) connect line into slave cylinder, remove cap and maintain fluid.
3)open bleeder valve and let fluid run out until there is a solid stream.
4)close valve, depress clutch pedal 5-10 times, wait 1-3min, repeat 3 times. 5) open bleeder valve, depress pedal, close bleeder valve.
Now when i tried this, i got to step 3 and all it was doing was dripping about 2 drops per second. i eventually got tired of watching it after about an hour and closed the valve and proceeded onto step 5. when the clutch pedal was pushed out there was a solid stream that came out. i think the new master cylinder is just a faulty one. i'm going to take it back tomorrow and retry the process. if the line is disconnected from the slave cylinder, shouldn't the clutch pedal have resistance because it's trying to push fluid that has no where to go?
