huntman58
- February 13, 2007
- Fremont calif.
- 2013 Dodge Advenger
Okay I have searched and I also have had this as a running problem for a time (over 3 years now and I still can not get it fixed!
Here is a link to my thread back in 2009 about it
http://www.explorerforum.com/forums/showthread.php?t=243082&highlight=bad+O2+sensors+dose
it now is showing codes 136 and 172 meaning both Right and left O@'s are saying lean so the PCM is enriching the motor as much as it can.
Okay after that post I have in the last year changed the lower and upper intake gaskets. Went back to a stock coil. Plugs are now only 1,000 miles old same with the wires. I did change out both O2 sensors again so they have been changed an average of every 40,000 miles but in reality in the last 40,000 they have been changed 3 times once because a shop damaged the wires when they did the tranny rebuild. I have a vac gage also in the truck and it is now reading about 14 inches most of the time but every now and then on a slight up grade such as an over pass it will drop to below 5 or 6 inches and then hang at around 12 for 20 to 30 miles.
Once again I have gone over the vac lines and can not find any leaks this includes the vac tee as I did take it off and clean it and check it out after reading a post on her thank you for that info who ever posted it!
So my questions are
1) can an over rich mixture make a motor run hot like this now and then but not all the time or do I most likely have a stat going out? (It was replaced also about a year ago with the intake gaskets.)
2) What is the likely hood that I may have a bad or going out PCM?
I know if it was only one O2 sensor I could by it went bad but both and left and right its hard to think they went out together but then again maybe they went out close to each other and not at the same time any one here of something like this?
3) At what kind of miles do the rings and or heads (valves) normally wear out on these motors?
4) Last any one know of a good way to hide the bald spot from pulling out your hair trying to fix an Explorer?
I would like to keep this thing as I have owned it from about 1996 and later have plans to do a SAS with a SOA lift and make it a toy from the DD it is now but at this point I have to keep it as a DD but the MPG is killing me not that it would ever get great MPG just that it no longer gets any thing worth talking about as a 1/4 tank gets me only about 50 miles and that is no good by any ones book for a stock motor.
Any and all help is welcomed and thanks for all I have learned from this sight also and as soon as a job is found I plan to become an elite member.
So my questions are
