dogfriend
Human-Animal Hybrid
- July 22, 2002
- Carmichael, CA
- '97 Sport 4x4
MONMIX said:for those of you following / helping look at this
http://www.pro-flow.com/tech info/troubleshoot.htm
Second one down.
It is from the Pro-M web site.
I really can't make heads or tails of what they are trying to tell me.
The codes they are talking about are EEC-IV codes; your codes are EEC-V (OBD-2). Code 41 is the code for always lean, code 42 always rich, code 91 is lean for the left O2 sensor.
Their troubleshooting hints assume that the sensor is the problem; this is not likely in your case because you already replaced the sensor and the same code reappeared.
They also seem to believe that some O2 sensors can break from thermal shock if the temp ramp rate is too high. It seems to me that this is probably true only under extreme conditions (racing) but I doubt this is the case for most vehicles; if the sensors failed frequently due to thermal shock, it would be a real problem for the OEMs (Ford) cause they would be replacing them constantly.
