XLT
- January 21, 2005
- Wausau, WI
- 1998 Sport SOHC 4X4
Well i have been searching on here for while becuase i have a little issue with my truck. I have a P0430 code popping up and it seems the three things to check are the catyltic converter, the bank 2 sensor 2 O2 sensor, or the camshift position sensor. But i thought the threads i mainly read on the camshift sensor were related to the v8. I had the check engine light about a month ago for this code and just cleared it. Well my last tank of gas saw about a 4mpg drop then what i usually get. I usually see 15mpg year around but it dropped to 11mpg which is by far the lowest i have ever seen in 3 winters of owning the truck. So i scanned my truck and the P0430 code came up once more even though no CEL was on. The cats on my truck are probably orginal and have about 125,x.. on them. I figured i will take a look at the camshift sensor and continue down the list. Does the drop in milage point to a possibe suspect? Otherwise my truck has been running normal and purs at idle. Just looking for any input.
