Code: P0743 TCC Question | Ford Explorer Forums - Serious Explorations
df_EB2000
St Paul, MN
'00 EB
Code: P0743 Question
I recently purchased a used 2000 EB explorer V8 with 69k. I have only driven the truck for a few weeks and everything feels fine with the transmission and shifting.
Yesterday I ran into a bit of a problem. I noticed when I started it up that the OD overive was off (light was on). I tunrd it off and thought nothing of it. Then on the way home after driving 30 or 40 miles the check engine light came on. I ran it over to checker auto parts and scanned for code P0743 Torque Converter Clutch Electrical Circuit.
I read a few threads and figure that it is probably a wiring issue. If anyone is familiar with this, where are the typical places to check the wiring? Is the solenoid and/or harness inside the TC? and any potential troubleshooting I can do.
The reason I ask it that there is a warranty on all lubricated parts and I am wondering if this would fall in that catergory?
There is an internal harness with the case connector, AND the external harness. Neither I would consider a lubricated part, although the internal harness does get bathed in fluid. There have been some good threads on here about harness problems... if you search 5r55E and harness I bet you will find some good info.
Doesn't FORD warrant the powertrain to 75K ?
Thanks for the info. I guess I'll have to do some digging around to see how the external harness looks.
As for the powertrain warranty, I'll have to give a ford dealership a call. I am not the original owner so I'm not sure if that will affect the coverage. That would be great if it was.
