mattwehrwein
- August 25, 2013
- janesville wi
- 1996 ford explorer
I just got done doing a timing chain in the 4.0 engine.
now the explorer has a p1400 code for Differential pressure feedback EGR Circuit low input.
I changed out the EGR valve (autozone brand) the EGR DPFE sensor and hoses from autozone, and I put a new egr tune in when I had the engine pulled for the timing chain. I also changed the egr solenoid as well.
None of that seems to help the code is still there. It Runs perfectly fine for a while but gets a rough idle that will cause it to stall out. Especially shifting into reverse and drive.
What else could cause this problem? Thank you for any help.
