code reading frenzy | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
code reading frenzy
mechjames
Richmond, BC
1994 Explorer XLT
code reading party
I got a bunch of codes today:
KOEO:
335 - PFE or DPFE sensor voltage out of Self-Test range.
CM:
214 - Cylinder Identification (CID) circuit failure
332 - EGR valve opening not detected.
KOER:
326 - PFE or DPFE circuit voltage lower than expected with zero EVR duty cycle.
soooooooo, whats that all mean? Seems like the EGR valve might be sticky. If I cleaned the valve, do you think it would all go away?
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
cjones101812
Avondale, AZ
06 Explorer EB
for 214 will your truck run?? i'll check the others later
manaen
Clear Spring, MD
2011 Xterra Pro-4X
well chances are you have a bad DPFE sensor, that will likely fix code 335, 332, & 326
for 214 you should check your camshaft position sensor I beleive that is what the ECU uses for CID data, although I would expect a CMP error, I'll need to do some reading on that one.
mechjames
Richmond, BC
1994 Explorer XLT
the truck starts and runs great.
although under low to mid throttle, it surges just a tad bit
full throtlle and idle is great. i think thats due to the egr not opening.
going to swap DPFE sensors and see what happens.
manaen
Clear Spring, MD
2011 Xterra Pro-4X
you should also check the EGR tube for blockages and all the vacuum lines to the DPFE
