Epalm18
- September 17, 2020
- Eureka, CA
- 91 Ford Explorer
Hello, I have a 91 Ford Explorer 4.0. Vehicle sat for a year and leaked water down to the computer. Replaced computer and then ran good. However, it only makes it about 15 miles then CEL comes on, loses power, idle ramps up to about 2 thousand RPM on side of road and dies once I give it some throttle (otherwise it will just sit there at about 2 thousand rpm until I kill it). Fires right back up runs great then later on down the road it does it again. It’s done it every time I’ve drove it now. It also seems to have an extended crank when cold. The 2 codes that are present are a 95, and an 87. Things I have replaced include: fuel pump, canister purge valve, throttle positioning sensor, computer, fuel filter, spark plugs, plug wires, fuel pressure regulator, water pump, thermostat, fan clutch, and radiator. I also made sure fuel cutoff switch was good. Please help! Any suggestions welcome as I am stumped and tired of throwing parts at it thank you!!
