CODES for 1999 Ford Explorer question | Ford Explorer Forums - Serious Explorations
thistles
Queensland
1999 XLT 4.0 V6 Wagon
I have a 1999 Ford Explorer XLT UR Model in Australia. Would anyone know what the following codes mean?
PO122 = TP-CKT low output
P0123 = TP-CKT high
P1125 = TP sensor intermittent
Thank you :)
TP is the throttle position sensor (CKT is circuit), so that would be a good place to start looking. It's a little unusual that you got all three codes. It could be a sensor problem or a wiring problem, so it would be a good idea to run some tests on the sensor and the wiring before you start replacing parts.
Replace or calibrate the Throttle Position sensor.
