local7teener
- April 11, 2007
- Chesterfield, MI
- 98 mountaineer v8
So i have a slightly lifted 98 mountaineer, i swapped the T-bars out for some qa1 coil over shocks with the RCD brackets. Put it all together and started checking clearances.. All good except i can't go stop to stop with my steering. The 90 degree fitting on the caliper hits the coil. I Drilled some 1/2" bolts into my lower control arms to limit my steering as its my daily driver.
So I need some stainless brake lines.. And cannot find them anywhere. Will another year fit? i just need a straight flexible fitting on block at the caliper. I can move it around and out of the way from there.
