J
JCase
That is not why efficiency is better with warmer air. It's because a cold air charge takes some energy during combustion to be heated - energy that could otherwise be used to provide mechanical motion. It's true that warm air has less oxygen which is why, normally, a real cold air intake would increase power. However, having a warm intake charge means less energy is wasted during combustion heating up the air/fuel mixture.
Good point too.
Yes, air density, throttle position, thermal conduction/convection all play a role along with other factors effect mpg and efficiency. I apologize for my oversimplified statement.
The air still has to make 2 90 degree turns flowing into the airbox, and out of the airbox. The cone filter removes both of these.
If your counting the air entering the box as a 90 turn, then I can see your point. But I don't think its a factor considering all the points previously made in this thread.
I was referring to fitment and placement of the OEM intake tube and that there is no room to drastically change the design for the better.
