Hello Josh P.How much more hp do you think the motor is making now? How much money have you invested in parts?
Yup the air must flow through the meter in the correct direction! We all make mistakes this one is just funny! Thanks for sharing
I recently modded a factory airbox to
Flow more air after deciding the aftermarket “airbox” or cold air kits for the 5.0 are over priced and still come with a crappy filter.
I added a second air horn to allow
More air in, simple effective.
Without some headers on that 5.0 you will never make more power you are only changing the sound and the throttle response. The factory exhaust manifolds are a huge bottleneck and they are choking the power you can make right now. If you truly want to make +25 Hp over the factory rated 215 you will need
Yes 410fortune, one day I will buy the maximizer headers. It just sucks that this application there are very limited options for headers. Also your right Mbrooks420, there is no way it is 15 to 20 hp. Thats why I said, it's a rough guess. LolYup the air must flow through the meter in the correct direction! We all make mistakes this one is just funny! Thanks for sharing
Without some headers on that 5.0 you will never make more power you are only changing the sound and the throttle response. The factory exhaust manifolds are a huge bottleneck and they are choking the power you can make right now. If you truly want to make +25 Hp over the factory rated 215 you will need headers
Get 500 Horsepower from a Junkyard Ford Explorer 302
Upgraded Lunati camshaft and GT40 cylinder heads on Ford Explorer Mustang 5.0L 302 V-8 with nitrous makes 500 horsepower.www.motortrend.com
Thanks CDW6212R. I'm not concerned whether I'm no where close to 300. But I just want a bit more power then stock. So like you said, just doing some cheap external bolt on. I want to avoid doing ANY crazy internal stuff. That gets expensive and complicated. So like you said, this is my focus.The 302 exhaust manifolds are hell in stock form(terrible air flow), and the one aftermarket choice is hell to install(an equal length design(hell to install)). The Ranger has had other 302 manifold choices for V8 swaps, I would look into those, thus the Ranger frame etc, might be a far better platform.
The stock exhaust is a single exhaust, not dual. A dual exhaust has two complete paths for the two banks of exhaust flow, thus two mufflers and two tail pipes. The manifolds are the worst part of the system, but the back half is also very poor(air flow is poor(half the flow of two mufflers etc)). The cat pipes are fair, 2.25" is decent for stock or mild power, but the four cats are of course restrictive. Remove the rear two, leave the O2's where they are, and add a muffler and tail pipe, somehow have two of everything, that's dual(high flow).
The stock air cleaner(not intake) is fine for well over 300rwhp, all OEM air cleaners are already cold air designs. It's possible to make them larger, but it's not easy at all, and not needed until you get above 300-350hp. The stock 5.0 is rated at 210hp, dyno testing would likely be 200hp, You will not gain enough to be near 300hp with minor changes. The exhaust is terrible, the intake elbow is very restrictive, the base engine is about the same as a Cobra 302(240hp in a dual exhaust Mustang with a manual trans). The heads, cam, and intake manifold are a bit small, the other major limitations end up costing a good 40-50hp compared to a typical car with 302 and manual trans.
So figure on upgrading some expensive parts, the heads/intake/cam/exhaust, before possibly approaching 300hp. The tuning will be required, so I'd begin on the easiest external things. That's good to aim at the exhaust, body etc, then the suspension and brakes will need some help. Work your way up to the big stuff, and plan slowly for a realistic budget. Good luck,
I’ve wondered what mine would gain if it got a tune. The few people I’ve talked to didn’t have any answers if it’d be beneficial enough to have it doneFord has a great system which will compensate for mild exhaust, intake and some cam changes easily and do it well. There is nothing mentioned in this build that requires a tune.
Probably 5-15 hp.I’ve wondered what mine would gain if it got a tune. The few people I’ve talked to didn’t have any answers if it’d be beneficial enough to have it done
Countless people have installed bigger exhaust pieces and then reported losing torque, low end etc. Of course all of them were untested seat of pants opinions. But I don't discount their opinions at all, I do disbelieve that any power was lost, their tune in the computer was no longer adding enough fuel to achieve the proper air/fuel ratio. If they would commit the same time and money they spent on the changes, to also retuning the PCM, they would gain torque, power at all rpm's. It wouldn't be huge gains, but going upward is still much better than going down in power.Ford has a great system which will compensate for mild exhaust, intake and some cam changes easily and do it well. There is nothing mentioned in this build that requires a tune.
Going from a restrictive manifold to long tube headers for example, you feel the power band shift up higher, what you no longer feel below the peak torque point, you feel above it.Countless people have installed bigger exhaust pieces and then reported losing torque, low end etc. Of course all of them were untested seat of pants opinions. But I don't discount their opinions at all, I do disbelieve that any power was lost, their tune in the computer was no longer adding enough fuel to achieve the proper air/fuel ratio. If they would commit the same time and money they spent on the changes, to also retuning the PCM, they would gain torque, power at all rpm's. It wouldn't be huge gains, but going upward is still much better than going down in power.
Almost nobody ever gets a tune for their Explorer, just the big guys doing the serious upgrades do it. I'm soon going to be hunting a Quarter Horse to do my tuning of my 98 project, after my Lincoln 347 swap and tuning. So I have a reason to get the software etc, to do more than one soon, this year I expect to be testing big exhaust parts on a stock 302. But it will be tuned to begin with, a base tune, then a base test, then modifications and repeat.
