cflecknell
- August 23, 2009
- Banff, AB
- 94 2-door 4WD
Ok, it's -29c outside this morning (-35c or something w/wind). Started it up, let it sit for a few mins to hopefully warm up a bit (plugged in all night).
Everything seems fine until I put it in reverse and back it out. I notice the clutch pedal is loose/no pressure for 90% of the stroke. Then while driving(all gears), changing gears us ridiculous. If I pump the clutch is will usually get better for the immediate time. While moving I think most of my shifting is just me sliding between gears with little to no help from the clutch.
When I bought the truck, the clutch slave cyl was toast, had the clutch plates and slave cyl. replace in mid Sept, and no issue until now. (Well, no clutch issues anyways).
I never remember horrible clutch issues like this when I owned manual trans before, bu that was also 10+ years ago, in a warmed part of the country.
Any ideas? I plan on heading back to the shop that did the clutch tomorrow, they at least gave a 6-mo warranty on everything.
Any ideas what's actually going on here? I wot' know what it's like in warmer conditions for a few days, cold until tues here.
Thanks!
Thanks!
