Cold Start problem | Ford Explorer - Ford Ranger Forums - Serious Explorations
Cold Start problem
OldTech
WillowSprings Mo
1994 Explorer XLT
My 94 Explorer has a problem with cold start more so in cold temp, surges and irratic idle till engine reaches operating temp then runs fine. Has had fuel pump replaced fuel filter, Iac Motor, IAT sensor, upper and lower intake gaskets, MAF cleaned, both 02 sensors, no CEL coming on. Only has 107,000 .miles engine looked new inside, has been well maintained , idles please.
FR-425
Used to be a road here.
Phoenix, AZ.
1994 Explorer Limited
Temp sensor. One is for the gauge, One is for the PCM.
Or you have a vacuum leak that seals up when heat causes things to expand.
OldTech
WillowSprings Mo
1994 Explorer XLT
I replaced upper and lower intake gaskets last week, still same issue, finding no vac leaks anywhere, need to find location for coolant temp sensor for PCM, runs great after warmed up. This 94 only has 107,000 miles been very well maintained before I bought it.
MrQ
Smokey the clutch is; Missed shift you did
Moderator Emeritus
Location
Humid, Damp, and Hot
Houston, TX
'98 EB, '93 Limited
The sensor with the single pin on the lower intake to the left of the thermostat housing is the gauge, there is a two pin on the opposite side of the housing, that is the one for the PCM.
OldTech
WillowSprings Mo
1994 Explorer XLT
Found it and replaced it will now see what happens in the morning when cold outside.
FR-425
Phoenix, AZ.
Disconnect battery to reset the PCM
OldTech
WillowSprings Mo
1994 Explorer XLT
Seems like if not one thing its something else. The ECT sensor helped a lot, but now back to the problem of popping back thru the intake at idle. I recently replaced upper and lower intake gaskets, the IAC , IAT sensor, fuel pump and filter new spark plugs and wires, both 02 sensors, still has no check engine light coming on, have reset PCM, what am I missing?
FR-425
Phoenix, AZ.
Timing chain may have jumped a tooth or two.
Time to have a look at the mechanical timing.
Centaurious
Pensacola FL
1994 Explorer Sport
Double check the plug wires and firing order. Ignition timing is off the crank and without shearing the key holding the Harmonic Balancer is almost impossible to break mechanically.
MrQ
Moderator Emeritus
Location
Houston, TX
'98 EB, '93 Limited
Sorry, about the "disagree." @OldTech . I think I was on my phone and hit the rating icon by mistake.
OldTech
WillowSprings Mo
1994 Explorer XLT
This only happens when cold, after it warms to normal temperature it runs fine. It idles so smooth when warm at times I look at the tach to see if its running . The idle surges and pops thru intake to air filter housing. I've seen this posted a bunch just haven't seen where anyone has figured it out.
