Well it's about time to start collecting the parts I need for the swap. I wiil be using a Dana 44 front axle and a fullsize 8.8" rear end from a 89 fullsize bronco. please give me any kind of insight on what I plan to use. All commentary is wanted
Edited with final parts
Dana 44 from 76 f-150
-78-79 coil spring towers spaced out with 3x4 steel
-Wildhorse crawler 5.5" coil springs.
-F-250 shock towers
-5.13 Yukon ring and pinion
-Master overall kit.
-Warn primium hubs.
-Cage offroad radius arms.
-78-79 stock tie rod
-Explorer stock drag link
-custom trackbar with heims. Bottom heim is a 3/4" heim and top is a 5/8" heim with 1.5" .25 wall DOM.
-Stock 76 f-150 trackbar bracket welded to a 3/16" plate of steel.
-7* C bushing kit.
-Bilstein 14" travel 5100 shocks
-Open Differential for now
-Timkin wheel bearings and seals.
-All new disk brakes and custom stainless steel brakelines
Fullwidth 8.8 from a 88 bronco
-Master install kit.
-weld on spring perches/ u bolts/ shock mounts. mountainoffroad.com
-custom shackles that are the same length of warrior shackles.
-skyjacker Add-a-leaf
-Lockright
-new drums with stock fullsize bronco e-brake cables and custom frame bracket.
-skyjacker extended brakeline for explorer.
-extended diveshaft with 1310/1330r basterd u-joint.
Wheels and tires
-36x12.5" TSL Radials
-15x8" black steel rockcrawler wheels.
-F-250 shock towers
-Warn primium hubs.
-7* C bushing kit.
-Lockright
Wheels and tires
