Cologne V6 Castings Research | Ford Explorer - Ford Ranger Forums - Serious Explorations
2000StreetRod
Staff member
Moderator
Greenville, SC
00 Sport FI, 03 Ltd V8
I've started researching the castings incorporated in the V6 engine manufactured in Cologne, Germany with emphasis on the 4.0L SOHC V6. The information I find will be documented in this thread to keep it organized. I encourage others to add to it and mention any errors.
The 4.0L OHV V6 engine was incorporated in the following vehicles:
Ford Aerostar (1990–1997)
Ford Explorer/Mazda Navajo
Ford Ranger/Mazda B-Series
The 4.0L SOHC V6 engine was incorporated in the following vehicles:
Ford Explorer/Mercury Mountaineer (1997–2010)
Ford Mustang (2005–2010)
Ford Ranger (2001–2011)
Land Rover Discovery 3/LR3 (2005–2009)
Mazda B4000 (2001–2010)
The first number in the casting number is the year of the casting (i.e. 97=1997, 5=2005)
OHV Castings
Block P/N xxxx-6010-xx, Cast Iron
90TM-AB
95TM,-AB
97TM-AA,-AB
Head P/N Left xxxx-6050-xx, Right xxxx-6049-xx, Cast Iron
L90TM
L90TM-BE
L92TM
L93TM,-AB
L94TM
L95TM-AA,-AD
L96TM
L97TM
L98TM,-AD
R90TM
R92TM
R93TM,-AB
R94TM
R95TM-AA,-AD
R96TM
R97TM
R98TM,-AD
Crankshaft P/N xxxx-6303-xx
90TM-AA,-AB
97TM-AA (8 bolt flywheel)
XL2E-AA (8 bolt flywheel)
SOHC Castings
97JM-AE
1L2E
Note: 1L2E-BB is a 4.6L V8 aluminum block
5L2E
5L2Z
I suspect the 2005 block casting is the one that reduced the clearance for the front (left) cassette pivot pin.
Head P/N Left xxxx-6050-xx, Right xxxx-6049-xx, Aluminum
L97JM-CD,-CE
L1L2E,-AA
L8L2E
R97JM-CD,-CE,-CF
R1L2E,-AA
R8L2E
97JM-AC (8 bolt flywheel)
5L2Z-AA (8 bolt flywheel)
