Color Options | Ford Explorer - Ford Ranger Forums - Serious Explorations
Color Options
Once the body work is finished i need to figure out if I should stay with the same EL YY colors... Strawberry Red and the off white color or if i should change ot another color...possibly a solid color for the entire vehicle. I have the Red interior though. Anyone seen an exterior color that matched well with the red?
Thanks
MONMIX
I fix dents
Moderator Emeritus
Millersville , Maryland
2000 Explorer Sport
Reds are not very versitle.
You pretty much need to stay with red or some variation there of. Maybe a candy apple or something would liven things up a bit.
Keep in mind any color chance will be noticable on your door jambs. Unless you spring for painting them too. With you in the middle of a door swap that helps but it still will increase the cost.
4x4Hunter
Watertown, NY
'91 XLT
Costs
I'm not really worried about the costs. I get the paint at good discount, Sherwin-Williams employee disc. and the painter is a friend of mine, so a case of beer is good for all
Thanks for the suggestions. How about Black?
MONMIX
I fix dents
Moderator Emeritus
2000 Explorer Sport
I LOVE black. But it is very high maintainace.
Your body work needs to be perfect.
But when black is clean, shiny and straight NOTHING looks better.
have2goski
Columbus
'91 Eddie
i would say black would be ideal also if you could pull it off. problem willbe making sure the body work is all really smooth in order to get a good finish.
I think if you went black maybe consider painting some of the interior trim peices to pull the black into the vehicle some more. I know there are people on here that have painted plastic peices here and there. and like said above the complete color change would necessitate addressing the door jams
