ViperPliskin
- June 6, 2008
- TX
- '99 XLT
Howdy. I'm looking for a little advise regarding camshaft selection. I know there's a load of information out there, but my question is fairly specific.
1999 XLT 5.0L going into a 1998 Ranger S/C (RWD) for street use. I want a jackrabbit off the line. High RPMs are not critical. Mild to moderate idle preferred. Minor bolt-ons...CAI, TMH, 1-inch spacer, performance tune. Otherwise stock...transmission, converter, heads, intake, gears, etc. Installed an E303 but now having reservations. Assume custom is not a great option for me.
COMP recommends 35-512-8
Duration at 050 inch Lift: 206 int./212 exh.
Lobe Separation (degrees): 114
Valve Lift with Factory Rocker Arm Ratio: 0.480 int./0.480 exh. lift
But I think I want something a little more aggressive, since I've already upgraded springs, rockers and pushrods. These are the other ones I've looked at.
COMP 35-510-8
Duration at 050 inch Lift: 208 int./216 exh.
Lobe Separation (degrees): 112
Valve Lift with Factory Rocker Arm Ratio: 0.533 int./0.544 exh.
COMP 35-514-8
Duration at 050 inch Lift: 216 int./224 exh.
Valve Lift with Factory Rocker Arm Ratio: 0.544 int./0.555 exh.
Any recommendations?
Much obliged.
COMP 35-510-8
COMP 35-514-8
Much obliged.
