Compass Module??
iowa_hick
Iowa
2002 Ford Explorer EB
I have a 2002 Eddie Bauer edition and when I got it, the compass module that goes behind the rear view mirror was missing. At that time, I found one on ebay and had planned to buy it later on. When I went back to do so, it was gone, which I thought was no big deal, but now I can't find another one on ebay or anywhere else.
Does anyone have any idea what the Ford part number for this would be? Or does it have a different name that I need to search for?
Thanks!
Jake
M compass module problem Stock 2002 - 2005 Explorers 3
S Interior mirror compass is hanging down! Stock 2002 - 2005 Explorers 0
0 Message where my odometer and compass are Stock 2002 - 2005 Explorers 2
L Temp/ compass problem Stock 2002 - 2005 Explorers 1
R compass dark Stock 2002 - 2005 Explorers 0
M Digital compass Stock 2002 - 2005 Explorers 4
zecolleman Compass zone Stock 2002 - 2005 Explorers 2
I 02 Explorer XLT broken compass? No Direction readout and no -- Stock 2002 - 2005 Explorers 3
C Compass Not Working... Stock 2002 - 2005 Explorers 7
T Compass Problem Stock 2002 - 2005 Explorers 4
M Compass/thermometer display Stock 2002 - 2005 Explorers 0
B No compass indication Stock 2002 - 2005 Explorers 7
K Need help calibarting my compass. Stock 2002 - 2005 Explorers 3
L Compass and Thermometer for 02 Stock 2002 - 2005 Explorers 5
W Compass won't Calibrate Stock 2002 - 2005 Explorers 3
J Front compass mount problem Stock 2002 - 2005 Explorers 1
C Can I add the compass/temp to my 02? Stock 2002 - 2005 Explorers 7
M Broken Overhead Compass/Temp display Stock 2002 - 2005 Explorers 0
O South by Southwest....Compass problem Stock 2002 - 2005 Explorers 1
S Compass stuck or broken? Stock 2002 - 2005 Explorers 2
N Compass - Ford Explorer 2004 EB Stock 2002 - 2005 Explorers 1
I Digital Compass not compassing! Stock 2002 - 2005 Explorers 2
G compass won't calibrate, no outside temp displayed Stock 2002 - 2005 Explorers 3
D Compass Problem Stock 2002 - 2005 Explorers 11
M Compass issues Stock 2002 - 2005 Explorers 1
K how to reset digital compass? Stock 2002 - 2005 Explorers 3
R Compass/Temp Feature...2003 XLS Stock 2002 - 2005 Explorers 0
C Compass Problems Stock 2002 - 2005 Explorers 3
KA3NXN 4X4 Transfer Case Control Module Stock 2002 - 2005 Explorers 3
L ABS Module Lines Stock 2002 - 2005 Explorers 0
B Rebuild CSM (Keyless Entry Module) Stock 2002 - 2005 Explorers 0
B Keyless Entry Central Security Module Malfunction Stock 2002 - 2005 Explorers 7
J Ford Explorer 2004 pats module problems Stock 2002 - 2005 Explorers 18
L 4X4 Control Module Stock 2002 - 2005 Explorers 1
E 2002 Explorer XLT vehicle security module Stock 2002 - 2005 Explorers 5
Y Random battery light and module voltage low Stock 2002 - 2005 Explorers 2
D 4x4 control upgraded module Stock 2002 - 2005 Explorers 2
H PATS Key Bypass and remote start install without bypass module. Stock 2002 - 2005 Explorers 16
C Jerking in drive train - 4 X 4 Module replacement? Stock 2002 - 2005 Explorers 1
J 1S4Z-19G365-AB ford Pats bypass module Stock 2002 - 2005 Explorers 4
J 2002 Explorer 4x4 stuck in low, new module and shift motor Stock 2002 - 2005 Explorers 2
S 2004 CSM Keyless module locations? Stock 2002 - 2005 Explorers 1
1 4x4 control module - What is my SUV without it? Stock 2002 - 2005 Explorers 21
H Which module Stock 2002 - 2005 Explorers 4
T ABS Module Issue Stock 2002 - 2005 Explorers 4
B 02 Explorer anti-theft module location? Stock 2002 - 2005 Explorers 2
W 02 explorer 4wd control module Stock 2002 - 2005 Explorers 0
M Help with 02 4x4 module wiring Stock 2002 - 2005 Explorers 2
G I need some help with a Central Security Module question, please. Stock 2002 - 2005 Explorers 5
imp Replace ABS Module Stock 2002 - 2005 Explorers 12
Similar threads
