ClubGitmo
- September 21, 2015
- AL
- 2004 Exploder
Just bought this exploder and it's already...exploding.
Cliffs:
Overheating
Coolant pooling on top of engine
Oil/Exhaust is fine
I've read these composite intakes like to crack. Is that the likely culprit? Can't see a crack, but this just happened after the sun went down. (Coolant is pooling under intake) Also the cruise control works intermittently... vacuum issue associated with failing intake?
Would a cracked intake cause these symptoms? What's the best route for a replacement if so? Also, estimated replacement hours from shade tree mechanic?
Cliffs:
Overheating
Oil/Exhaust is fine
