Compressor venting Coolant...
moret
Silver Spring, MD
'93 XLT
The quick and dirty is that a valve on the rear of the A/C compressor is sputtering every time the system is engaged. Below are more details. Thanks in advance for any insight you can provide...
Background:
I have a '93 XLT, which has been professionally converted to R-134. For the past 3 years, each summer I've recharged the system with a pound of coolant myself. This year, after recharging the system, the air was warm in about 2 months. So, I took it in and asked them to find the leak. They said there was no leak (much like the last time I asked a shop to find it) and recharged it.
The problem:
Two days after they recharged the system, a valve on the rear of the compressor (anyone know what this valve is called?) started to exhaust the coolant. I shut off the AC, and subsequently the engine. The coolant continued to exhaust until the system was empty.
I took it back to the shop, they replaced the valve, evacuated, and recharged. After running for 10 seconds, the new valve started to sputter. Once the AC was turned off, it stopped. They said it was the compressor. They've replaced the compressor, evacuated, and recharged. Before it was out of the garage, they started the AC. Again, within 10 seconds, the valve started sputtering coolant, and would stop once the clutch was disengaged.
The questions:
What is this valve on the back of the compressor called?
What would cause it to sputter?
If the coolant was contaminated, either in the shop's tank or due to a malfuntion in the shop's equipment, could this be the cause?
Sorry for being long-winded, and thanks again,
-Moret
shamaal
Friensdwood, Texas
91 Mazda Navajo
It's the high pressure relief valve. Shown on right in picture. If it is indded the valve opening, a couple possibilities come to mind:
1. Bad valve
2. Blockage in system
Sometimes there is damage to the grooves for the o'rings in the connector block that goes to the back of the compressor that gives the appearance of the valve opening. I would think there would be a very high indication on the high pressure gauge that the A/C techs would see.
If the coolant was contaminated with particulate matter sufficient to cause significant blockage that could be a possibility.
A Explorer 2006 AC compressor clutch engaging and disengaging A/C & Heater systems - HVAC 0
S 06 Explorer A/C compressor cooling issue A/C & Heater systems - HVAC 0
K 2003 Ford explorer EB AC Compressor issue A/C & Heater systems - HVAC 0
C 1996 Ford Explorer AC Compressor O Ring / Seal Size / Source / Part Number A/C & Heater systems - HVAC 1
O 1992 Ford Explorer XLT Compressor issues A/C & Heater systems - HVAC 5
1 A/c compressor running but not cycling on and off A/C & Heater systems - HVAC 2
B can the a/c clutch & pulley be removed & replaced without removing the compressor 20 A/C & Heater systems - HVAC 0
J Serpentine Belt to bypass AC Compressor? A/C & Heater systems - HVAC 4
B 98 Ranger Compressor On & Off A/C & Heater systems - HVAC 17
J Air Compressor "Siezed UP" A/C & Heater systems - HVAC 9
P A/C compressor high pressure release valve - what "non-captive" means? A/C & Heater systems - HVAC 0
G Blowing fuses even after I unplugged compressor A/C & Heater systems - HVAC 17
B Compressor just stopped A/C & Heater systems - HVAC 4
F A/C Compressor A/C & Heater systems - HVAC 4
G Torque spec for manifold line to the compressor A/C & Heater systems - HVAC 2
N Loud racket from compressor A/C & Heater systems - HVAC 5
M A/C (compressor clutch) will not energize immedately A/C & Heater systems - HVAC 1
E New ToughOne Compressor + Dryer + Firestone recharge = Cool not Cold A/C & Heater systems - HVAC 5
D Car compressor not working A/C & Heater systems - HVAC 0
J AC compressor blew up again A/C & Heater systems - HVAC 0
Badspell68 AC compressor oil - What is it, does compressor need its own too? A/C & Heater systems - HVAC 1
P No cold air/compressor problem?? A/C & Heater systems - HVAC 1
M Is the low pressure / compressor cycling switch adjustable? A/c cycles on highway A/C & Heater systems - HVAC 4
B AC Compressor Will Not Run A/C & Heater systems - HVAC 0
D Air Conditioner Compressor A/C & Heater systems - HVAC 4
F Ac compressor bolts A/C & Heater systems - HVAC 3
S A/C Compressor Clutch noise A/C & Heater systems - HVAC 1
MidnightRebel07 Any ever remove their A/C Compressor? Still want heat but don't use A/C. A/C & Heater systems - HVAC 2
K Replacing A/C Compressor in 98 Explorer 5.0 A/C & Heater systems - HVAC 0
S 98 Ranger 4.0l a/c compressor kicks on with heat? A/C & Heater systems - HVAC 4
H a/c compressor. not start A/C & Heater systems - HVAC 0
X Compressor On & Off, 140lb running pressure! Help A/C & Heater systems - HVAC 6
X Compressor On & Off, 140lb running pressure! Help A/C & Heater systems - HVAC 0
T a/c compressor clutch rattling A/C & Heater systems - HVAC 4
B eatc swap, no compressor engagment A/C & Heater systems - HVAC 3
B Adjusting Clutch Gap on the Ford FS10 Compressor A/C & Heater systems - HVAC 3
W Need help with new A/C compressor kit A/C & Heater systems - HVAC 2
J R12 compressor replacement A/C & Heater systems - HVAC 1
R 1997 Ranger. A/C compressor cycles even though freon was added. A/C & Heater systems - HVAC 1
G 1999 Explorer XLT with a compressor issue. A/C & Heater systems - HVAC 2
S 2000 Explorer compressor clycling A/C & Heater systems - HVAC 3
M No power to the A/C compressor. A/C & Heater systems - HVAC 2
C 94 Explorer a/c compressor leaking in center A/C & Heater systems - HVAC 0
T Ford Explorer Compressor Staying On A/C & Heater systems - HVAC 0
D Help,AC Compressor is discharging coolant A/C & Heater systems - HVAC 3
C leaky compressor A/C & Heater systems - HVAC 0
C Compressor replacement. A/C & Heater systems - HVAC 1
L AC compressor clicking enging surging A/C & Heater systems - HVAC 0
X ac compressor A/C & Heater systems - HVAC 1
B A/C Compressor cycles On and Off A/C & Heater systems - HVAC 4
Similar threads
