SUPPLIES:
1 sheet of air duct sheet metal (found it near ductwork in Lowes)
1 roll of adhesive foil and foam duct insulation (the stuff i got had an R rating of 3.0)
1-4 3/4" self-tapping metal screws
1 section of adhesive foam 3/4" pipe insulation
1ft section of 3/4"wide x 1/8"thick aluminum stock
TOOLS
Tin Snips or some other means of cutting thin sheet metal
Utility Knife
Tape Measure
Power Drill (for self tapping screws)
CONSTRUCTION
1. cut sheet metal to match the diagram above (do not cut along vertical center line!)
2. bend the sheet metal cutout 90° along vertical center line marked in diagram
3. apply adhesive foil-and-foam duct insulation to both sides of the metal cutout (i cleaned each side of the metal with windex just before applying the adhesive insulation to keep any oil, grease, dirt, etc from interfering with the adhesive backing on the foam/foil insulation.
4. apply the adhesive pipe insulation around the edges of the heat shield to help it get a good seal against the inside of the hood and in the corner where the air filter goes.
5. apply the adhesive pipe insulation around the inside of the 4.5" hole where the intake tube/MAF sensor comes through the heat shield
6. install the heat shield and secure the front with a self tapping screw as seen in this picture
http://i126.photobucket.com/albums/p84/aklmfreak/Heat%20Shield/IMG_1465-1.jpg
7. use the Aluminum stock and drill a couple of holes to make a support for the rear of the Heat Shield and bolt under factory bolts as shown in this picture
http://i126.photobucket.com/albums/p84/aklmfreak/Heat%20Shield/IMG_1463.jpg
8. Install Filter and Intake pipe accordingly, make whatever variations may be necessary to make your intake system work with the heat shield. here are a few pics of how my system turned out.
http://i126.photobucket.com/albums/p84/aklmfreak/Heat%20Shield/IMG_1466.jpg
http://i126.photobucket.com/albums/p84/aklmfreak/Heat%20Shield/IMG_1467.jpg
http://i126.photobucket.com/albums/p84/aklmfreak/Heat%20Shield/IMG_1468.jpg
http://i126.photobucket.com/albums/p84/aklmfreak/Heat%20Shield/IMG_1469.jpg
i know these directions probably arent the best but lemme know if anyone has questions, i'll be glad to answer them. just be sure you are careful around the vacuum lines below the airbox area. and yes, i had to nearly fold my heat shield in half in order to install it, so dont be afraid to mash it whatever way you need to to get it to fit. once it slides into place you'll see how everything fits together around the other engine bay components and characteristics.
as far as supporting the heat shield i just kinda redneck rigged it up, feel free to make any variations you want, if you come up with a better way to mount it, lemme know! i got lazy and just wanted to get the project done.
also, the filter i have in these pictures is an APC which i found out to be a PIECE OF CRAP (which i wasnt surprised cuz i just bought it cuz it was cheap), so i returned it and payed 9 more dollars for a comparable universal K&N Filter. overall, i think it turned out pretty nice, i can definitely feel a difference in acceleration and i can use less throttle while cruising. no i dont have a scanner so i have not been able to check actual intake air temperature, sorry. i'd really appreciate some feedback! this is my first DIY thread!
