Redskins1099
- December 12, 2012
- 1993 Explorer Limited
Hello, I have a 1993 Explorer Limited
I had issues with the truck just shutting off. Ran codes, came back the Air Sensor was bad, I replaced it. Truck ran great for an hr. Let it it sit, truck would start, idle horribly and shut off. Thought maybe some bad gass, I put in some sea foam, let it run for awhile. The next day truck once again drove great. Parked it for the night, the next day, same issues came back. Ran codes again, came back that my IAC was bad, So I replaced that, once again truck ran awesome for a day. The next day, same issues, replaced the fuel relay,and put on a new thermostat ran great once again for a day. Same story as before, the night went to start it, my battery gauge and rpms started to surge, rough idle back. I had my ALT checked today, came back fine. Fuel pump sounds strong also, also has a brand new battery.Checked fuel pressure also, was right where it should be.Also checked the N saftey switch, I think that what it's called and that was fine also.
-Replaced Air Flow Sen, truck ran great for 1 day
-Replaced IAC, truck ran great for 1 day
-Replaced Fuel Relay and thermostat, ran great for 1 day
-Issue back, rough idle, battery gauge and RPMS jump, truck sometimes shuts right off
-Fuel Pump sounds strong every time
-New Battery
-Alt checks out fine.
-Fuel pressure checks out fine
-N safety switch fine
Any Ideas or tips?
-New Battery
Any Ideas or tips?
