Connecting DVD player via 12v converter | Ford Explorer Forums - Serious Explorations
kware1
Boston, MA
2002 Eddie Bauer
I connected a 110v dvd player to my Pioneer AVIC D2 using a 12v converter. The result was signal noise. Any suggestions on a better way to do this?
dont use a 110v dvd player. use a 12v one meant to be installed in a car
In Car DVD
I couldn't locate one. Do you know who carry these?
O yes. I guess I was trying to avoid an in-dash unit, as I have a Pioneer AVIC D-2 in there now. It has AV inputs. But I guess I can mount an in-dash under the seat though. Thanx.
Power inverters that convert 12VDC to 110-120VAC usually produce alot of noise, the AC output is either a square-wave or sawtooth-wave output instead of the nice smooth sine-wave output that audio gear needs. The noise filtering in an AC pwr supply was designed to filter the sine-wave output but it doesn't handle a square wave or sawtooth wave output very well. There are higher-end DC-AC converters that produce a much cleaner AC output but the price of them rises very rapidly as compared to the more common and less expensive DC-AC 12V converters. What's really sad is that the power supply in a home DVD unit takes the 120AC and converts it (in many cases) to 12 or 24VDC and then that is further regulated down to a 5VDC B+ supply line for the digital components.
i have an in-dash mounted in my center counsel(sp?). you can mount them anywhere you can find room. the possibilities are endless!
It isn't fancy but you could hook one of those portable dvd players with the a/v out up to your system. I did something like this, you can either add an additional 12v outlet or hardwire it in. It's a little backyard mechanic ish but it works.
