yavapaires
- February 24, 2011
- Dewey, Az
- 1996 XLT
When the rear wheels are off the ground, shouldn't the front wheels pull thetruck when either 4wd setting( 4wd auto, or 4wd low) is selected? The vacuum disconnect seems to be working fine. With engine running, front wheels both off the ground, they turn in opposite directions as they should with open differential, and 4wd switch in either selection. With BWM switch in manual, the driveshaft cannot be turned more than about 1/2 turn when 4wd engaged. All seems normal to me, except front wheels will not pull. Any help is greatly appreciated, as I am not up on all this automatic stuff. I would like to have a MANUAL tc.
