aldive
Elite In Memoriam
- January 17, 2001
- 1999 XLT
Has anyone used a Cool Coolar on their oil filter?
Looks like this might be a useful accessory. And for those of us who have external auto tranny filters it might be to ticket to lower tranny temp.
Liquid Cooled Automotive Engine (Road Test)
This test was an actual highway test. The car used was a late model Corvette equipped with digital readout oil temperature and coolant temperature gauges. On a 72 degree F. day, at 65 miles per hour, the oil temperature read a constant 221 degrees F. The water temperature was 195 degrees. The corvette was then pulled off the road and a Cool Collar was installed. Testing was then resumed. Within a distance of five miles the Cool Collar was responsible for lowering and maintaining the oil temperature at 203 degrees F.
Summary: Our tests again indicated a 12% approximate reduction above ambient temperature of oil heat. On similar testes, it was found that after installation of the Cool Collar the oil temperature will typically drop near to the level of the engine coolant temperature.
http://www.shop.com/amos/cc/main/ca...C-Whitney---Automotive-Cool-Collar-Oil-Cooler
