Coolant leak but no sign of leak | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Fordman999
2003 Ford Explorer XLT
So I have a very slow coolant leak and I've gotten under the car and I do not see a single hose that has any sign of coolant leaking. I've followed the hose from the coolant fill and coolant return lines and no sign of any coolant. Anyone have any idea where this coolant is leaking from possibly?
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
extra-medium
Charlottesville, VA
2002 Mercury Mountaineer
Is your passenger floor board wet or discolored carpet? Also is your exhaust clean and clear or is it lightly tinted white and smells kinda sweet?
LMHmedchem
2002 Explorer XLT v8
If you live in a spot that is cold in the winter, you can get very small leaks around many of the hose connections. Most of these just have spring clamps that don't hold very tightly and the change in size of metal parts that happens in the cold can cause these connections to be a bit leaky untill the system warms up. These are generaly very small and nothing you would notice visually (like a puddle on the ground), but you do lose coolant over time. Some of this would depend on how fast your coolant is dissapearing. I would check all of the other sugestions first because there is nothing much you can do about the leaky spring clamps ofter than moving to Arizona for the winter. Also, if the coolant is winding up in your engine and going out your tailpipe, there may be much bigger fish to fry.
If you don't live somewhere cold, well, nevermind.
LMHmedchem
Fordman999
i'll check that I do have a bad catalytic converter now could it be related??
Fordman999
Which engine OP? Browsed through your 50 past posts and couldn't find anything.
If 4.0 SOHC check the lower thermostat housing. Very common failure on the SOHC V-6.
Sticky: Add Complete Vehicle Specs To Your Profile ;)
http://www.explorerforum.com/forums/showthread.php?t=375816
thanks I will add my info and I do have a V6 SOHC I hope that's the problem. Also my Catalytic converter went bad was wondering if coolant does leak into the engine how is that possible? I suspect that also might be the problem after reading some other replies. I will try the thermostat first but how can I verify that the coolant might be leaking into the engine? if it is?
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Rather than chasing your tail searching for coolant leaks, borrow a coolant pressure test kit available at most larger auto parts stores. Call around. Pay the refundable deposit in cash if you don't want to wait 5-7 days for your bank to process the refund when you return the tool. Also, thanks for adding your vehicle specs. Keep us posted.
http://www.valvoline.com/our-products/antifreeze-products/g-05-antifreeze-coolant
TechGuru
Location
Texas
2003 XLS 4X4 4.0L FLEX
swshawaii
Kailua-Oahu, Hawaii
Sorry guys, completely missed this. Was the engine over heated? If so, sounds like classic head gasket failure. Is the engine oil a milky white color, or do you have excessive water or vapor coming from the exhaust? If so, start by checking compression. Although lower thermostat housing failure is common and could be the cause of over heating, it's a minor repair compared to head gasket failure.
Fordman999
Nope but you are on the right track
swshawaii the engine did not overheat. I think it might be the thermostat housing since that is a common problem and you were right by guessing V6 SOHC engine so yeaah I'm gonna check that.
