cofs52
- January 25, 2011
- CT/VT
- 1997 XLT 4x4
1997 V8 5.0L
189,000 miles
the truck was losing small amounts of coolant for awhile. I let it go, and just topped off the reservoir every once in awhile. the other day, i could smell that sweet, sweet odor of coolant. I was going uphill, and for the first time since owning the car (second owner, as of 2005) the thermostat gauge started to head towards the H. Didn't get all the way there, but it was accompanied with a loss of power and refusal to accelerate.
Parked at my destination, and looked under the truck. Looked like I ran over Slimer from Ghostbusters. Waited a while, and checked radiator. Pretty much bone dry. Filled it with more fluid.Got home, more fresh fluid everywhere. Took mental note and went to bed. Next morning, checked radiator and coolant levels - a little over halfway. Thats a lot of coolant loss from the raditor for only 16 miles of driving over 12 hours. Topped off.
Now, I just use water to fill the radiator because the coolant is pricey. Haven't had problems (gauge moving towards H, loss of power) since, but I have to refill radiator every 2 days with about a 1/2 gallon or more water.
i did notice that coolant continues to leak overnight/while the car is parked. Most of the pooling is just inside the driver side tire, pooling off the axle and other parts in that area. nothing from radiator (replaced a few years ago). nothing from thermostat area (replaced a few years ago). No visible coolant when inspecting under the hood, you have to lay under the vehicle. even then, though, it is hard to trace.
when you do lay under it, the point to which my eye follows the stream is visible in the attached picture. seems to be the bottom of the engine, front left corner (driver's view). that is where the coolant is. nothing higher up from there, nothing heading towards the passenger side from there, nothing towards the driver along the engine from there.
no weird sounds. runs and starts no problem as usual
(as usual = the last 89,000 miles since purchase)
thoughts, suggestions?
my intended course of action: 1) this excellent forum, 2) pressure test, 3) upon diagnosis, repair with friend or send to shop.
189,000 miles
