ejscarfo
- March 17, 2010
- Islip, NY
- 1996 Explorer XLT
Hey guys! Happy Friday, at least for some of us. Anyway, I have a coolant leak that I need to locate. I saw coolant on the ground for the first time last night. I am hoping its an easy fix like the last leak (broken clamp on the lower radiator hose). The leak seems to be more on passenger side almost under the radiator. The oil cooler lines are wet and I found coolant in the wire loom containing the positive cables from the battery. The water pump is dry (the weep hole is up top, correct?) and it doesn't make any noise. I am thinking there's either a split hose somewhere down toward the bottom where I can't see it or the radiator has given out (it has 135K on it). As I am not too familiar with the 5.0 Explorer (my last one was a 4.0), can anyone suggest what to look for? The leak seems to be too far forward to be a gasket on the engine, so I am thinking its the radiator.
Any help is appreciated!
