I replaced the lower housing with a new one, and it leaked worse than the old split one! It is in such a blind spot, and I wondered if I failed to tighten the sensors sufficiently, so unable to see the leak anymore, I pulled the intake again, and took everything back out and re-sealed the threads. Put it all back together, and coolant just running out the back of the valley onto the starter and Y-pipe. So I pulled it all back down again, and no third time was not a charm, I replaced one of the sensors with a BWD while I had it back out, and a new O-ring, etc. Well it still leaks all over the place AND the new sensor was no good, it reads COLD, never moves the gauge. So finally I can see the Chicom OEM upgraded part is in fact where the leak is coming from, around the large insert. So I am returning the housing and the sensor, and have ordered a DORMAN unit, will try that. I am becoming fairly efficient at the Removal & Replacement of the upper intake! Holy crap I hope the next parts are good.
