nooberiffic
- August 19, 2009
- Utah
- 93 XLT
My Dad borrowed my sploder to pick up some groceries and noticed that there was a small puddle of coolant when he left to parking lot to come back.
I went out and checked the oil (clean) and the overflow tank (empty). Took the rad cap off and noticed it was a couple quarts low. Topped it off with water and started the motor to see if I could located the leak. No leak.
Since he noticed it on the way back I thought it might have something to do with the thermostat opening. Correct. When thermostat opened it started leaking from the bottom passenger side, near the petcock. doesnt look like it is coming from the actual petcock but somewhere in the lower right half. I loosened the shroud and chekcked and it seems to be coming from the gen area of the petcock.
Is it common for them to fail in this area? could it still be the petcock o ring?
