Coolant leak
Rick9089
Illinois
97 explorer 4.0 vin x
My explorer is leaking coolant from the rear passanger head area. Most likely a head gasket but just want to make sure there is nothing else back there that could be leaking. It is not the heater core hose any ideas would help
Rick9089
Illinois
So i had a chance to start tearing the engine apart. Luckily i saved the exhaust manifold for last which i am glad i did because the head gaskets where not the problem. Turn out to be the lower intake plenum gaskets where the cause. So i guess my advice is if you have a similar leak make sure you rule out the lower intake plenum gasket( by lower intake plenum i mean where the thermostat bolt too) hope this helps since there was plenty of views and no replies.
