Coolant Leakage | Ford Explorer Forums - Serious Explorations
  • Explorer Forum license plate frames are available 2 for $12, or 4 for $17. For photos and more details CLICK HERE
Coolant Leakage
george17592
2006 Explorer
Hello all,
Ive been having a coolant leak for the past few weeks. I cant exactly tell where its coming from. All the hoses look in good shape, and the thermostat housing looks good as well. I took a look under the car and noticed coolant dripping from a pulley. I cant tell exactly where its coming from and its starting to leak heavily! Any ideas?
Thanks!
If it's on a pulley it could be the upper radiator hose or the water pump.
V6 or V8?
Also, coolant can travel a long way before it hits the ground. Easiest way to find a leak is to put a coolant pressure tester on and pump it up. The only leak I couldn't find this way was a cracked cylinder head (don't worry, that wasn't the Explorer).
