shaneybob
- August 17, 2005
- TX
- '96 AWD
My wife has a 96 XLT AWD with the 5.0L V8 as her daily driver. I checked the coolant several days ago (first time in a month or so) and there was nothing in the reservoir tank and the radiator was about half full. So I look around under the car and see nothing. It hasn't been leaving any coolant on the garage floor and has not been running hot according to the temp gauge, other than the gauge doing the slow dance between 1/4 and 1/2 way. So I topped the coolant off and drove it 10 miles or so over a couple of days with no leaks. We went out last night and this morning I see a nice 3 foot diameter wet spot under the car, but nothing really showing. Check the coolant and the radiator is full and the res. has dropped about 1/4 inch below the cool level. So I start it up for a minute or so and notice a nice dripping coming off the oil filter shroud. I looked as good as I can and don't see and leakage coming from the lower radiator hose or the water pump hose on the engine oil cooler connections. Doesn't mean it's not coming from a hose, but the filter is really in the way to see properly. I had just called the local Firestone Service Center last week about getting the radiator hoses, cap, and t-stat replaced as well as a flush ($300) because I'm not mechanically inclined, and the dealership is too expensive on most things. Well I could do the maintainence, but I'd end up messing something else up like aways, so I stay away from anything but oil changes and the like anymore
Is there instance of the the oil coolers leaking coolant often? I've searched this site and only found one other mention of the OEM ones at all. And I've seen they are entirely cost prohibitive to replace. If it is the cooler what would I need to do to remove it and go with a stock filter attachment? Just have a remote filter attachment put in and a different lower hose? I don't tow anything anymore and we are planning on selling it soon anyway.
Any thoughts would be greatly appreciated.
