Coolant overflow=boiling..temp gauge=not very hot | Ford Explorer - Ford Ranger Forums - Serious Explorations
Wagonized
abbotsford bc
97 5.0 limited
lately my X has been going through some coolant.
My temperature gets a bit higher than usual but is definitely not overheating. points slightly above 90 degrees at most. But when i shut off the truck the coolant in the overflow tank is boiling and from the sounds of it so is the water in the rad.
what could be the problem here?? Bad thermostat perhaps, or a bad gauge even
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
sounds liek the guage isnt properly reading whats going on... any boiling coolant means at least 212 degrees.....
boiling can be a few things, i would first look at the acc drive belt to make sure it is still there, after that, the thermostat, then radiator.... leaking water pumps will cause coolant consumption and boiling conditions
PTBishop
Vancouver, WA
1991 XLT
put it on an emissions anlyzier (spelling) and check for hydrocarbons in the radiator...notice a milky substance in your radiator?
gijoecam
Village Idiot
Trenton, MI
98 ExSport, '00 F-150
Radiator cap fixes it 98% of the time.
Start there before you worry about blown head gaskets or real overheating with a bad temp sending unit for the gauge.
-Joe
Wagonized
abbotsford bc
97 5.0 limited
took the thermostat out and now no problems at all.
easy fix...somewhat. thermostat housing is a bitch to get off...could have definitely been engineered better
marragtop
balt, md
91, 92, 95, and 2000 xlts
Best way to get the T-stat housing off is to move the serp belt out of the way. That way the tensioner pulley is out of the way of the 3rd bolt.
