Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
The temp gauge on my Explorer Sport stopped working after some repair work to the thermostat housing. I am thinking the coolant temp sender is bad and want to replace it.
I am confused as most auto parts stores such as rock auto, have the Temp Sensor and temp sender in the same catagory. Are these screw in coolant sensors both the same or is there one specifically for the sender and one for the Sensor? It would seem the units are interchangable?
Also I am thinking that the temp sender on my '98 X sohc motor is the gray one on the right of the housing.
Any help is kindly appreciated
