Daivd Shade
- July 12, 2009
- Columbus, Ohio
- '94
I recently purchased a 4 wheel drive '94 Explorer with a 4.0 V6 and an A4LD (C3). 204,000 Miles on the clock, good body except back bumper and of course rocker rust, but the rest is in exceptional shape for the miles and the front end is real tight.
More important it runs pretty good and the 4WD both low and high works.
It was very cheap $50 although it's price also included $108 worth of 4 wheeler brake parts and maybe 20 hours of labor, but all in all we are good friends, so it was a friend deal.
It runs well, and thanks to this forum now has Overdrive again since I adjusted the bands. (Thanks)
This vehicle is a second vehicle, a backup, but also 4WD for winter and something I can haul 4 x 8's of ply in and maybe even fit a bike.
Anyway, he (the PO) tells me that it needs a radiator because it leaks.
The radiator is in good condition and is not leaking.
I have a 7 lb. cap on it and the PO said he modified the thermostat so that it couldn't close (I have to look at it, and probably replace it).
I can find no external leaks at all.
But it goes through a gallon of coolant in about 150 miles.
Last Sunday I pulled plugs on the drivers side bank just to look at them.
They all looked a little rusty, I have never seen that before and I am not a newbie mechanic (I build 2-stroke race motors).
They were all dry and if anything looked like they were running lean, (but I'm a 2stroker, so I'm used to wet oily plugs).
They were well used Autolite Platinum's with the center electrode looking pretty rounded. Rain stopped me at the first 3 plugs.
I bought a new set and fearing that I have a head gasket leak started on the other bank of cylinders first.
They were worn, rusty looking but totally dry.
When I finally got to the last plug, closest to the driver, it was definitely wet.
So, my question is, what could be leaking that gets some water to all the cylinders but allot of water to the one plug?
Are there any water passages in the intake manifold where a gasket could leak?
Any other ideas?
I had let the truck sit for a few hours before pulling the first 3 plugs, so maybe the wet plug had a chance to dry and when I installed new plugs the engine was still kind of warm so the wet plug did not have a chance to dry.
But from the color of the plugs, I am convinced that coolant is getting into all the cylinders.
I downloaded a shop manual but have been unable to get it to open.
I guess I will buy one next payday, but that's still 7 days off.
Thank you,
This forum has already helped me and has some great reading.
Dave Shade
Any other ideas?
Thank you,
Dave Shade
