I own a 91 Explorer,4.0,4x4,auto w/AC.
I have been having a coolant leak problem for several weeks.
It started out w/ having to put in about a half gallon every two weeks. I looked an looked but could not find a leak. Then my altenator went up and upon replacing it after i had removed the hose from the aircleaner to the TB I saw antifreeze under the thermostat housing, so I assumed that the thermostat gasket was leaking.I replaced the stat and gasket,upper and lower hose's as well as the heater hoses.
Now it spews antifreeze, from where I dont know... I dbl and triple checked all the hoses and everything I replaced is not leaking. The weep hole on the water pump is dry. the upper parts of the engine is dry also. after taking it out and parking it again Ill see coolant all over the front axel and under the engine.
PLEASE HELP
PLEASE HELP
